Hatch pattern
Hi
I use AutoCAD or ZwCAD for construction drawing drafting before and would like to change to Bricscad. When I use trial version to open my drawings, it can show existing hatch pattern but not create new. Say the material is concrete and I use AR-CONC in AutoCAD or ZwCAD, but I can't find this type in Bricscad.
Is it possible to import the hatch pattern?
Thanks.
Terry
0
I, too have licenses for AutoCAD & ZWCad, but have migrated to Bricscad.
You can easily copy hatch patterns from AutoCAD & ZWCad using a text editor, adding them to your .pat file.
You need to copy them into BOTH: program's default.pat file, and user profile's default.pat file.
PS: It is always prudent to copy/rename existing default.pat file before making changes in case something goes awry.0 -
0
