How to open a DWF File? Can Bricscad do that?
I have tried to open a .DWF file (received from customer) but Bricscad V12 (latest release) seems not to be able to do so.
Anyone knows how to do?
0
Hi Svend,
_DWFATTACH is yet to be implemented in Bricscad. This is how you would normally work with this type of file. The workaround would be to open the file in a DWF Viewer and print it to PDF, or an Image, either of which Bricscad can work with.
Regards,Jason Bourhill
0 -
I have now tried to use the suggested DWF Viewer, but it cannot view the file I have.
I must try Autodesk's Design Review ......
0
