Reset to default
how to get the default settings?
if i changed so many settings and dont knew anymore whitch i changed.
Is there an possibility to get the 'factory' settings?
Regards
Martin
Regards
Martin
0
Dear Martin
Settings are saved in a user profile. To restore the built-in hardcoded settings: choose User Profile Manager in the Tools menu, then click the Create button, optionally rename the profile and set it current. Close and restart Bricscad to use the new profile.0 -
Hi Martin,
Have some instructions here http://www.cadconcepts.co.nz/creating-a-new-user-profile/, which may be of help.
Regards,Jason Bourhill
0 -
Thanks to you both.
Thats the point i was looking for.0
