Another Old MTEXT Bug
I have noticed that when inserting dimensions (using centered between extension lines) that the MTEXT is justified middle center (as it should be). If there is one line of text then this point is in the middle center as it should be. If there are 2 lines (or any even number) then this point is centered between the lines of text (also as it should be) but if there are 3 lines (or any odd number other than 1) then it centers between the text instead of in the center of the middle line. I constantly have to move text up half a line to adjust for this.Anyone else notice this or know a fix? does Intellicad plant to fix this?
0
We have started an overhaul of all dimensioning. regards, sander, Bricsnet
0
