Where can I find the specific forum for BricsCAD developers?
I write some plugins for CAD. Where can I find the specific forum for BricsCAD developers?
Best Regards
0
File a support request and ask to register as a developer and you will get access to the developer forum. I wouln't say it was super active and you will probably get just as much help in this forum or at www.theswamp.org but I suppose you cover your bases
0 -
I already made it, but I can't find a "native" forum of BricsCAD for programmers. I know about theswamp.org, thanks.0
Hi Andrey, once your support request has been made you should get a response from the bricsys team that will give you access to the developer section via chapoo. This is where the developer forum is found. Just give them a couple of days if you haven't been contacted yet as I don't know what sort of time off they may take over the Christmas period.0
