Shortcut Key's
Hello,
How can i work with shortcut key's like CTRL+C, CTRL+V, CTRL+Z. (Copy, paste, etc.)
Thank you!
0
Hello,
Thank you!
0 -
Hello,
Thank you!
0 -
Select entities in your drrawing that you want to copy or cut, then press CTRL+C or CTRL+X. Then press CTRL+V and paste the entities into your drawing at the mouse cursor by clicking the left mouse button.0
No, the problem is that on my machine the Ctrl+C or Ctrl+V is not working. There is something wrong in the software functionalities. I press the combination but the command is not launched.
0 -
Hi Nicoleta,
By default these keyboard shortcuts are defined in the base menu, which in BricsCAD is called 'default.cui'. Possible reasons:- You have changed your base menu to some other menu, which doesn't hold any keyboard shortcut definitions. Commonly done by loading a partial menu as the main menu. Partial menus are meant to be loaded alongside the base menu, not instead of;
- You have edited the default.cui, modifying the keyboard shortcuts.
- You have V12 and have loaded a partial menu, which initially causes keyboard shortcuts to be disabled. This is a bug (fixed with V13). If you restart BricsCAD the issue should resolve itself.
Regards,Jason Bourhill
dlgCUI-RevertToDefaults.png0
