V13 OPEN AN ACAD DRAWING
I have the folowing problem. I can't open a drawing made by ACAD 2013 with Bricscad V13. Can you give me a hint for this?
0
Hi Nicoleta,
BricsCAD currently supports .dwg up to AutoCAD 2012. You will either have to go back to the source and ask them to save the drawing to an earlier format, or use something like DWG TrueView and convert yourself.
The ODA recently announced support for the 2013 file format, so I would expect to see an update to V13 in the near future.
Regards,Jason Bourhill
0 -
Bricsys rep's prediction (Nov. 2011) ".... current estimate is to add 2013 format support to BricsCAD during the first quarter of 2013."0
