3D files
 Hello, i have question regarding importing 3D.dwg files in BrycsCAD V13.
                 Every time when i try to import or open 3D.dwg file (last was about 5Mb) BrycsCAD shut down automaticly and it shows error report.
   So any advice how to fix that problem.
 Thank you.
0
            This user forum is for user-to-user communication. If instead you want a Bricsys analyst to investigate why opening the 3d file fails, please file a support request and attach the drawing.
Kind regards,
Hans De Backer0
