Installation Troubles
 I just bought 2 seats of BricsCAD 13 Classic.  The program installed fine on my new laptop it fails to run telling me I am missing REDCore.dll and I should reinstall the program to try and correct things.  Well, the reinstall doesn't fix things either.
Please help!!
Thanks!
Jeff
Win7 Ultimate - Brand new install
  • Hi,
    Could you try to launch the installer again, and choose Modify, and check the 'Rendering' checkbox ? This should get you up and running.
    Meanwhile we will fix this in our installer, so in any case an upgrade with the next release should fix the problem as well.
    kind regards
    Pieter
  • Perfect!  Thanks Pieter!
