autocad commmand Filter
Hi,
i want to ask you is there command :
FILTER (i use it from autocad 2014 to today in autocad map 2012) you write doen in command line!!!!
ADD SELECTED?
ADD vertex whene mouse selected polyline?
best regarded
Katarina
ADD SELECTED?
best regarded
Katarina
0
Hi,
FILTER (i use it from autocad 14 to today in autocad map 2012) you write down in command line!!!!
ADD SELECTED?
best regarded
Katarina0 -
Here is my version of filter command (reduced, source code is included)0
Hey Josip,
Great job!
Another closed gap.
Thanks0 -
Hi Mustafa,thanks for feedback.If you have time you can see my solutions for the design of sewage.Applications are in the Croatian language, soon will be available in English and German.ISS (cad for designing Internal Sewage System)ESScad (cad for designing External Sewage System)0
Hi All,
I found here some discussion regarding Auto Cad, If you want more discussing & better solution, visit to the below link:
Cad Services
It will be more easy to contact them and send your problem details to get solution online.0
