Deviations from AutoCAD functionality for those porting existing software
Dear Steve,
just some answers ...
for #13 XData :
under which conditions do you get ((1001 . "LYR_STD") (1000 . "BASIC")) in AutoCAD,
where BricsCAD does not return the same sequence ?
As this should be fixed, indeed.
Using (entget ename (lisp "*")) or (entget ename (lisp "MyApp")) returns the same
list using -3 sentinel as AutoCAD does
for #1 / #2 :
yes, this is a known difference ... I will try to get this fixed for Lisp + BRX;
internally that extra newline is necessary for some connabds, but for Lisp + BRX we
should find a way to suppress extra newline
for #3 Lisp -> ARX -> acedCommand :
will try to reproduce, this needs to be fixed
for #4 (entmake) for existing anonymous blocks
shouldn't (entmod) be used better ? (entmake) always creates a new object ...
maybe, you can erase the existing block definition just before creating a new one ?
for #5 '+' syntax in menus
already fixed, will be in upcoming V13.2.
for #11 '49' missing DXF code for linetypes
I will fix this right afterwards
for #12 (ssget) order
yes, also a known issue ... I already have a fix for this, which will provide
same order as AutoCAD does, for "X", "C", "CP", "W", "WP" modes ... will likely
be included in one of next BricsCAD;
BUT
it is simply not correct to rely on particular order of entities within a selectionset;
of course, AutoCAD has that behaviour, but it is not guaranteed at all.
Furthermore, ARX/BRX provide reactor interfaces for entity selection - therefore, applications
can add/remove entities to/from selectionsets, causing unpredictable entity order.
So in summary, it is bad application logic to rely on the entity order - strongly
advised to rework the application logic here.
As mentioned, it will get better in BricsCAD, but likely will never be 100% as in AutoCAD.
For these and the others, please feel free to send us a "support request" (bug report),
1 item per request please, so we can better schedule the issues to our developers.
Especially the issue #3, #6, #8, #11, #13 seem worth to be documented.
If possible, please provide a sample dwg and/or some Lisp snippets to reproduce,
this makes it easier for us to reproduce.0 -
@Steve:
You should be aware that many commands will accept keywords that are not shown on the command line.
For example:
#9
(command "._POLYGON" "6" mscc_cp "_C" PR)
Also works in BricsCAD.
#14
(command "._ucs" "_R" "PRE-ENLARGE" "" "_DEL" "PRE-ENLARGE")
Regarding issue #11:
Note that there are in fact two standard linetype files (imperial and metric).
But, FWIW, I cannot reproduce the problem (BricsCAD V13.1.22):
[code](entget (tblobjname "ltype" "center")) =>
(-1 . )
(0 . "LTYPE")
(5 . "9E")
(330 . )
(100 . "AcDbSymbolTableRecord")
(100 . "AcDbLinetypeTableRecord")
(2 . "CENTER")
(70 . 0)
(3 . "Center ____ _ ____ _ ____ _ ____ _ ____ _ ____")
(72 . 65)
(73 . 4)
(40 . 50.8)
(49 . 31.75)
(74 . 0)
(49 . -6.35)
(74 . 0)
(49 . 6.35)
(74 . 0)
(49 . -6.35)
(74 . 0)
)[/code]0 -
The Forum has eaten some of the entiylist in my previous post. It should be:
[code](
(-1 . <Entity name: 0ce4a6f0>)
(0 . "LTYPE")
(5 . "9E")
(330 . <Entity name: 0ce68660>)
(2 . "CENTER")
(70 . 0)
(72 . 65)
(73 . 4)
(40 . 50.8)
(49 . 31.75)
(74 . 0)
(49 . -6.35)
(74 . 0)
(49 . 6.35)
(74 . 0)
(49 . -6.35)
(74 . 0)
)[/code]0 -
@Steve:
Oops:
#9
Does work in BricsCAD but the result differs from:
(command "._POLYGON" "6" mscc_cp (strcat "@0," (rtos PR 2 6)))0 -
Dear Steve, Dear Roy,
for #11 : linetype dxf 49
indeed, (entget (tblobjname "LTYPE" ...)) works correctly;
it is (tblsearch) and (tblnext) which incorrectly omitted dxf 49 ... as the data list shows, Acad creates the datalist not by internal (entget),
but in dedicated code; we also do so since V13, for performance reasons.
The issue with dxf 49 has been fixed internally, and such case was added to the test system.
for #13 XData list
I'm highly interested to get this solved, if there is any difference to AutoCAD - please provide a small sample and/or code snippet
Many greetings !0 -
for #13 XData :
list using -3 sentinel as AutoCAD doesI suspect this is due to using Xdata on layer 0 combined with very old code. We are setting and getting the data via result buffers in C++ and we have written a wrapper class for managing the result buffers so unfortunately it's rather difficult to isolate the specific code involved. The bottom line is that using the same wrapper in both AutoCAD and Bricscad produced different results as I have described. I have attached a drawing with xdata on layer 0 if that will help. As requested I will post a support request for this as well.
maybe, you can erase the existing block definition just before creating a new one ?In this case we are using entmake to redefine a dimension that already exists in the drawing so I don't think erasing the definition will work, at least not without a lot of extra work.
BUT
advised to rework the application logic here.Agreed, as mentioned, this is very old code, however, in this case it is dealing with objects we created in a previous operation so the order is "known".For these and the others, please feel free to send us a "support request" (bug report),
this makes it easier for us to reproduce.Will do.0 -
@Steve:
Oops:
#9
(command "._POLYGON" "6" mscc_cp (strcat "@0," (rtos PR 2 6)))Exactly! For my purposes, the odd rotation the first method produces is very bad.Thanks0 -
Dear Steve
for #13 XData :
so I assume, your C++ code returns the XData resbuf list via acedRetList()/ads_retlist() fucntion ?
Can you document that resbuf list list here, so we can simulate such acedRetList/sds_retlist() with such a data list, and see
why our Lisp returns a different representation ?
Mainly, the sequence of resbuf type + value ... it is then easy to construct such data in our test system.
for #12 ssget order
as mentioned, most cases are already fixed internally, on my machine ... so good chances to get that fixed in one of upcoming BricsCAD versions.
Many greetings !0 -
issue #13. XData difference
just fixed in our code ... now behaves as expected; many thanks !0 -
Regarding #8 DCL issues, when using RADIO buttons;
ACAD the buttons all appear as unchecked in the Dialog Box and there is a nil value for all variables.
Bricscad the 1st button appears checked however returns a nil value, letting the user think the button as it appears is acceptable.
This requires the use of a conditional statement to be sure the results are as expected.0 -
@Bruce:
You are right, but the problem only seems to occur when the radio_column or radio_row is the first 'clickable' tile in the dialog. When you say 'returns a nil value' I assume you mean the callback function for the radio_button is not triggered even though is appears as selected.
After some experiments I have found a workaround for this. Don't know how this will work in AutoCAD.
LSP:
[code](defun c:DCL_Test ( / N_Accept N_Option1 N_Option2 N_Option3 dclFile)
(defun N_Accept ()
(print (get_tile "options"))
(print (get_tile "option1"))
(print (get_tile "option2"))
(print (get_tile "option3"))
(defun N_Option1 ()
(print "Option 1 was selected")
(defun N_Option2 ()
(print "Option 2 was selected")
(defun N_Option3 ()
(print "Option 3 was selected")
(setq dclFile (load_dialog "DCL_Test"))
(new_dialog "DCL_Test" dclFile)
(action_tile "option1" "(N_Option1)")
(action_tile "option2" "(N_Option2)")
(action_tile "option3" "(N_Option3)")
(action_tile "accept" "(N_Accept)")
(start_dialog)
(unload_dialog dclFile)
(princ)
)[/code]
DCL:
[code]DCL_Test : dialog {
label = "DCL_Test";
: radio_column {
key = "options";
value = ""; // Set value as workaround for radio problem.
: radio_button {key = "option1"; label = "Option 1"; value = "1";} // Set value as workaround for radio problem.
: radio_button {key = "option2"; label = "Option 2";}
: radio_button {key = "option3"; label = "Option 3";}
ok_only;
}[/code]0 -
Dear Bruce, Dear Roy,
indeed, using "radio_buttons" the Lisp code should definitely set initial conditions ...
as for "radio buttons", one of them must always be selected, so it seems to be moe an AutoCAD issue,
which allows this unlogical behaviour.
But it is also a question of good style, to initialise the DCL values when the dialog is opened, not relying on defaults
(ok, maybe for edit fields etc.).
However, I will check with Tijs, if we can mimic this (formally incorrect) AutoCAD behaviour here.
Many greetings !0 -
Torsten,
I am ok with how things are now, I was just bringing to the attention of any interested programers. However as Roy pointed out, even within Bricscad the only instance where the 1st radio button appears selected is if the radio column/row is the first set of inputs within the DCL.
Bruce0
