Mixed CAD Environment Tips and Tricks
Would it be useful for the BricsCAD user community to compile a library of tips and tricks for utilizing BricsCAD in a mixed CAD environment, primarily with AutoDesk applications?
Tip1
BricsCAD handles AutoCAD textmask a little differently. It may be useful to move the wipeouts to a separate layer. I have this run as each drawing opens to help.
(setq WipeOutSSet (ssget "x" '((0 . "WIPEOUT"))))
(if WipeOutSSet
(progn
(setq sLayerName "C-SITE-MASK")
(setq sCLayer (getvar "CLAYER"))
(if (= (tblsearch "layer" sLayerName) nil)
(command "-LAYER" "make" sLayerName "c" "254" "" ""))
(command ".chprop" WipeOutSSet "" "la" sLayerName "")
(setvar "CLAYER" sCLayer)
(setq sMessage (strcat
"WIPEOUT object may have been moved to layer C-SITE-MASK"
"\nPlease confirm that the plotstyle is set to MASK"))
(alert sMessage)))
Tip1
(if WipeOutSSet
(progn
(alert sMessage)))
0
I think a Wiki would complement this forum well, not only for tips regarding a mixed environment, but for gathering all kind of information that should be easily retrievable (HowTos, FAQs, Hardware / OS compatibility database...).
I am no specialist in this domain, though, and do not know if these systems are easy to set up and maintain.0
