tframes
in Other
I autocad there is a command called "tframes". It turns the frame on or off of a raster image. if the frame is off, you cannot select it. If the frame is on you can select it by the edges. What is the similar command in BricsCad...or where is the setting for that?
Thanks.
mh
0
The command is imageframe.0
thanks for the info.0
@Mike,
TFRAMES is part of AutoCADs Express tools.
There is an Express Tools for BricsCAD, which contains most of the same, including TFRAMES. Available from http://www.cadwiesel.de/
Regards,Jason Bourhill
0
