acet-error-init
Dear All,
currently I'm trying to export the autocad lisps to briscad. Almost all lisps work fine except for a few who are listed with acet-error-init. Probably briscad will not work with these codes or have it wrtten in a other way. Anyone who could help?
;;;----MAKE LAYER -------;;;
(defun LayerMake (name / )
(if (not (tblsearch "layer" name))
(command "_.layer" "M" name "c" "white" "" "lw" "0.20" "" "") ;make layer
(command "_.layer" "s" name "")
;;;;---- MAKE DIMENSION -----;;;;
(defun MakeDim (dim / )
(setvar "CMDECHO" 0)
(acet-error-init (list (list "CLAYER" (getvar "clayer") ) 0)) ;;"DIMCLRT" 2
(LayerMake "Dimension")
(setvar "CMDECHO" 1)
(if (= dim dimensionarc)
(dimensionarc)
(command dim)
(while (> (getvar "cmdactive") 0)(command pause)) ;until dimlinear stopped
(acet-error-restore) ;restore acad variable
;;;---- Make dimlinear ----;;;;
(defun c:dli ()
(MakeDim "_.dimlinear")
Regards
Hello,
(acet-*) functions are Express Tools dedicated and will not work within BricsCAD. You can simply to try comment them or replace with plain LISP codes.
Regards, Vaidas0 -
You should be able to change
[code] (acet-error-init (list (list "CLAYER" (getvar "clayer") ) 0)) ;;"DIMCLRT" 2[/code]
to
[code] (setq oldclayer (getvar "clayer"))[/code]
and
[code](acet-error-restore) [/code]
to
[code](setvar "clayer" oldclayer)[/code]
acet-error-init accepts a list of system variables to store. It sets an error handler, clears the old system variable list used by the function, calls acet-ui-progress-done, gets the values of the variables that were passed to the function and stores them along with the value of ucsicon, sets cmdecho to 0, and may set (command "_.undo" "_begin"). For your program the return value from acet-error-init is ("CLAYER" "power" "ucsicon" 0) . acet-error-restore sets (command "_.undo" "_end"), restores the stored settings, resets the error handler, sets highlight to 1, and sets cmdecho to 1.
0 -
Dear Martin, Dear All,
many thanks for all the hints !
I will review our (acet-error-xxx) functions, implement and/or fix the problems, so that V14
will get working + compatible versions.
Many greetings to all !0 -
Torsten,
I've used the acetutil.lsp that I received many years ago with a lisp extender for Autocad LT with great success. I have many of the express tools (legally obtained when they were available for free download many years ago) working well. I had to write replacements for acet-str-format and acet-str-find, which were implemented in arx, to get the routines I use to work.0 -
@Daniel
The following code is similar to the acet-error-init /acet-error-restore
[code]; CCL:GSVAR
; Usage:
; Place at the start of your routine to save environment variables, and call
; at the end to reset.
; To save environment variables present a list of the variables to save
; e.g. (CCL:GSVAR '(cmdecho osmode expert blipmode dimtxsty))
; will return a list of what they are currently set to e.g. the above will
; return something similar to:
; ((DIMTXSTY "CCL-ROMANS") (BLIPMODE 0) (EXPERT 0) (OSMODE 8706) (CMDECHO 1))
; To reset the variables back after running your routine simply pass
; something other than a list to CCL:GSVAR
; e.g. (CCL:GSVAR T)
; This will reset the list and return nil.
; Requires : Nothing else
(defun CCL:GSVAR (varlist / e_var s_val var2reset)
; Make sure the visual lisp extensions are available. Required by AutoCAD
; Bricscad will work fine without
(vl-load-com)
(cond ((= 'LIST (type varlist)) ; if you pass CCL:GSVAR a list it will save each of the variables to a list
(setq *ccl:gsvar_list* ()) ; make sure that our global variable is reset
(foreach e_var varlist ; for each member of our list
(setq s_val (list e_var (getvar (vl-symbol-name e_var))) ; retrieve its current value using GETVAR
*ccl:gsvar_list* (cons s_val *ccl:gsvar_list*) ; and add it to our list
) ; end setq
) ; end foreach
) ; end LIST condition
(T ; if you pass anything else it will reset each of the variables in our list
(while *ccl:gsvar_list*
(setq var2reset (car *ccl:gsvar_list*)) ; retrieve the first variable to reset from our list
(setvar (vl-symbol-name (car var2reset)) (cadr var2reset)) ; reset it using SETVAR
(setq *ccl:gsvar_list* (cdr *ccl:gsvar_list*)) ; remove the reset variable from our list
) ; end while
) ; end T reset condition
) ; end cond
(if *ccl:gsvar_list* *ccl:gsvar_list* (prin1)) ; return our variable if exists, otherwise make a quiet exit
) ; end CCL:GSVAR[/code]
I'm not familiar with acet-error-init /acet-error-restore, but you need to couple the function above with an appropriate error handler to make sure that variables are always reset.
[code]; *ERROR*
; Error handler should anything go wrong
(defun *error* (error_msg)
(cond ((eq error_msg "console break") (CCL:GSVAR T)); Console break, no message, reset environment variables
((eq error_msg "Function cancelled") (CCL:GSVAR T)); Function cancelled, no message, reset environment variables
((eq error_msg ())(CCL:GSVAR T)); error not stated, no message, reset environment variables
(T (princ (strcat "\nERROR: " error_msg )) (CCL:GSVAR T)); Print error message if given, reset environment variables
); end Cond
(prin1); exit quietly
) ; end *error*[/code]
Lee Mac has a good explanation on the error function and usage on his website. http://lee-mac.com
Both of the functions above would sit in your on_doc_load.lsp so that they are available to any functions that require it.
An alternative approach in the specific case of your example may be to use the Toolpalette. You can define a commands on the Toolpalette to use specific layers, linetypes etc, which allows you to do pretty much the same thing without using any code.
Regards,Jason Bourhill
0 -
thanks for the hints :-)
I'm going to add all that "acet-xxx" and "acet::xxx" stuff to BricsCAD Lisp engine;
and I'm also going to add most of the "acet-xxx" functions from AcetUtils.arx as well ...
So I'm optimistic to get this (mostly) done till V14 release; documentation will be also be added
to the Lisp Developer Support Package.
0
near oll of the (acet-*)Functions are rebuilded by Torsten and me.
I build the Expresstools (from AutoCAD) new for Bricscad. During this i had to create many,many of this acet functions.
You can download the expresstools for bricscad (http://www.cadwiesel.de/cadwiesel/cw_download_01.php?id=230) and use the Acetutil.des for the needed functions. Here ist the list of included functions
[code]acet-4-match
acet-acad-refresh
acet-alert
acet-and-match
acet-angle-equal
acet-angle-format
acet-annotation-ss
acet-appid-delete
acet-arxload-or-bust
acet-att-subscript-duplicates
acet-autoload
acet-autoload2
acet-autoloadarx
acet-blink-and-show-object
acet-blink-and-show-object_do
acet-blk-match
acet-blktbl-match
acet-block-make-anon
acet-block-purge
acet-bs-strip
acet-calc-bitlist
acet-calc-round
acet-calc-tan
acet-cmd-exit
acet-currentviewport-ename
acet-dcl-list-make
acet-dict-ename
acet-dict-name-list
acet-dtor
acet-dxf
acet-elist-add-defaults
ACET-ENT-CURVEPOINTS
acet-ent-geomextents
acet-error-init
acet-error-restore
acet-explode
acet-file-attr
acet-file-backup
acet-file-backup-delete
acet-file-find
acet-file-find-font
acet-file-find-image
acet-file-find-on-path
acet-filename-associated-app
acet-filename-directory
acet-filename-extension
acet-filename-ext-remove
acet-filename-path-remove
acet-filename-supportpath-remove
acet-filename-valid
acet-file-open
ACET-FILE-REMOVE
ACET-FILE-WRITEDIALOG
acet-filter-match
acet-fscreen-toggle
acet-gc-match
acet-general-props-get
acet-general-props-get-pairs
acet-general-props-set
acet-general-props-set-pairs
acet-geom-angle-trans
acet-geom-arc-3p-d-angle
acet-geom-arc-bulge
acet-geom-arc-center
acet-geom-arc-d-angle
acet-geom-calc-arc-error
acet-geom-cross-product
acet-geom-delta-vector
acet-geom-image-bounds
acet-geom-intersectwith
acet-geom-is-arc
acet-geom-list-extents
acet-geom-midpoint
acet-geom-mid-point
acet-geom-m-trans
acet-geom-object-end-points
acet-geom-object-fuz
acet-geom-object-normal-vector
acet-geom-object-point-list1
acet-geom-object-z-axis
acet-geom-pixel-unit
acet-geom-pline-arc-info
acet-geom-point-inside
acet-geom-point-rotate
acet-geom-point-scale
acet-geom-rect-points
acet-geom-self-intersect
acet-geom-ss-extents
acet-geom-textbox
acet-geom-unit-vector
acet-geom-vector-add
acet-geom-vector-d-angle
acet-geom-vector-parallel
acet-geom-vector-scale
acet-geom-vector-side
acet-geom-vertex-list
acet-geom-view-points
acet-geom-z-axis
acet-geom-zoom-for-select
acet-get-att
acet-getvar
acet-group-make-anon
acet-groups-sel
acet-groups-unsel
ACET-HELP
acet-init-fas-lib
acet-init-getmenu-pos
acet-init-placemenu
acet-insert-attrib-get
acet-insert-attrib-mod
acet-insert-attrib-set
acet-layer-locked
acet-layer-unlock-all
acet-list-assoc-append
acet-list-assoc-put
acet-list-assoc-remove
acet-list-group-by-assoc
acet-list-is-dotted-pair
acet-list-isort
acet-list-m-assoc
acet-list-put-nth
acet-list-remove-adjacent-dups
acet-list-remove-duplicate-points
acet-list-remove-duplicates
acet-list-remove-nth
acet-list-split
acet-list-to-ss
acet-lwpline-make
acet-mod-att
acet-not-match
acet-or-match
acet-pline-is-2d
acet-pline-segment-list
acet-pline-segment-list-apply
acet-plines-explode
acet-plines-rebuild
acet-point-flat
acet-pref-supportpath-list
acet-rtod
acet-safe-command
acet-set-CmdEcho
acet-setvar
acet-spinner
acet-ss-annotation-filter
acet-ss-clear-prev
acet-ss-drag-move
acet-ss-entdel
acet-ss-filter
acet-ss-filter-current-ucs
acet-ss-flt-cspace
acet-ss-intersection
acet-ss-mod
acet-ss-new
acet-ss-redraw
acet-ss-remove
acet-ss-remove-dups
acet-ss-scale-to-fit
acet-ss-sort
acet-ss-ssget-filter
acet-ss-to-list
acet-ss-union
acet-ss-visible
acet-ss-zoom-extents
acet-str-esc-wildcards
ACET-STR-FIND
ACET-STR-FORMAT
ACET-STR-FORMAT2
ACET-STR-FORMAT3
acet-str-lr-trim
acet-str-m-find
ACET-STR-REPLACE
acet-str-space-trim
acet-str-to-list
acet-sysvar-restore
acet-sysvar-set
acet-table-name-list
acet-table-purge
acet-tbl-match
acet-temp-segment
acet-tjust
acet-tjust-keyword
acet-truncate-2-view
acet-ucs-cmd
acet-ucs-get
acet-ucs-set
acet-ucs-set-z
acet-ucs-to-object
acet-ui-entsel
acet-ui-fence-select
acet-ui-getcorner
ACET-UI-GETFILE
acet-ui-get-long-name
ACET-UI-MESSAGE
acet-ui-m-get-names
acet-ui-pickdir
acet-ui-polygon-select
acet-ui-single-select
acet-ui-txted
acet-undo-begin
acet-undo-end
acet-viewport-frozen-layer-list
acet-viewport-lock-set
acet-viewport-next-pickable
acet-wmfin
acet-xdata-get
acet-xdata-set
m:acet-ui-txted
[/code]0 -
Ok..... Uhhh you are good isn't enough. You are the king!! This makes life so much easier....0
Martin,
Do you still intend to release your work as non-encrypted files? You version of Express tools works well if it is the only code loaded, but there are many conflicts with the other lisp and ODCL routines I use. Without unencrypted files it is very hard to find and fix the conflicts.0 -
Hi Martin
The acet functions are all included in the Acetutil.des. There are also the autoload and menuload on startup included. I'll seperate all the acet functions and send it to you for testing. Than you are able to test without all expresstools functionality. But i'll keep the acet* functions compiled - sorry
If there are faults inside the functions i'll fix this as soon.
Many Regards
Martin0 -
Thank you for the update.0
now i seperated the acet functions from the other stuff.
attached is the new acetutil.des.
I also updated the Expresstools package.
There is now one file more inside (acettest.des), which contains the moved functions to make the tools working as bevore.
If now somebody needs acet* functions without the Expresstools, they can take only the Acetutil.des allone.
Please let me know if there are errors.
use the email: cadwiesel at cadwiesel dot de
Martin0
