Purge command problem
Purge command does not change the size of the files. Occasionally the size of the file are growing
purge "all" "x" "yes to all" "y"
Thanks
0
commad line write.. purge "all" "x" "yes to all" "y"
Thanks
0 -
            For blocks within blocks you could possibly need to do 2-consecutive purges.0
Depends how much unreferenced "stuff" your dwg contains.
Just Purged a cluttered dwg now. Was 17Mb, now 9Mb.
Per Bruce's suggestion, I find it always prudent to do 2 consecutive purges.
0 -
            0
