V14 Platinum 3D Constraints
I'm new to 3D modelling in BricsCAD. Can anyone tell me if there is a way to see all the "constraints" associated with a specific component that has been inserted into an assembly? For example a component may have a concentricity constraint that I would like to remove. Moving down through all the constraints one at a time does highlight were the constraint is within the assembly, but this is very time consuming. It would be nice if the constraints for each component were shown below the component in the Mechanical Browser window (see attached screenshot). Any suggestions would be appreciated.
Regards,
Dennis
Regards,
Dennis
0
Dear DennisClick the 'Group by Entity' button in the Mechanical Browser to see which constraints apply to a component.0
That worked like a charm! How did I miss that? Thanks so much!!Dennis0
