line with different z-values to 3d-polyline
How can i convert a line with different z-values to a 3d-polyline?
                0
            The "Join" command appears to work.0
            no...if i select only one line BricsCAD crashif i selct more than one line i get the message: "Invalid index"example file attached0
            You are correct. I can only Join two lines with this command. Perhaps this a support questions.
Sorry0 -
You can download our free tool PEDIT3D
from the Bricsys download centrer
http://www.bricsys.com/common/applications/application.jsp?app=593&apploc=1180
Good luck
Jochen
0 -
            @Jochen: Nice tool!But with thausend of lines it would be a long task.Always crazy that some tools are not part of the standard cad systems.0
Hi Florian,
Thank you "for the flowers" ;-)
I'm working on a PEDIT3D-Version with Multi-function. If you want to be a beta-tester, please contact me.
Regards
Jochen
0
