Layers
I need to clean up drawings to make graphics. Sometimes I have into the same layer some stuff I need and another stuff I need to take away. Is there any easy way to clean up when averything is into the same layer??
0
...ha ha typical beginners problem.....select by properties e.g.color or so and move it in properties dialog to a new layer.....1.click to properties button2.select by properties..etc
0
