Access_Violation (0000005) in Module MFC80u.DLL at 001B:5A029AEC
Having problems with my new computer after migrating Briscad.
I am running V10 am not sure if its installed correctly couldn't find (or never had a disk for the V10 upgrade so had to use the V7.1.00161-1 disk that I had)
0
Hi Peter,
I would raise a support request for a link to download V10. By default the last 2 major releases are available from the downloads page.
In the meantime you could run with the V14 trial. You may even find you like it
Regards,Jason Bourhill
0
