Strategy for dividing a drawing out into x-refs
If you are up to date on the Unpurgable Layers thread, I described my effort to simplify a drawing that had become too cumbersome with many layouts and layers. Briefly, I put a lot of the basic building parts in a separate drawing that I X-ref back into the drawing. But, that actually ended up creating a lot more layers, even if the number of layout tabs were reduced. But, my viewport layer settings were all lost in the process.
Another weakness I came across with X-refs is that they are blocks, and so the utilities I was using to freeze layers inside viewports don't work. I know the LAYOFF and LAYFRZ commands can select an object inside a block to freeze/off it, but, I am not aware of a similar command for viewport layers. Is there one?
So, I now think I may just go back to a back-up I created before I started, and just accept that my drawing will have a lot of layout tabs. Perhaps it would be easier if when I started at the beginning, I planned on using the X-ref. But, even that does not addresses all the difficulties of an Xref. Any arguments against that statement?
-Joe
0
Hi JoeTo VPFreeze xref layers: make the viewport the active viewport (double click inside the viewport), then launch the LayFrz command and choose Settings > Viewports > Vpfreeze. Click the entities of which you want the layers to be frozen in this viewport.0
Thankyou Mr. Verdonck.I will mention an issue that confused me about this command before. When you first use LAYFRZ, the settings sub-command seems to be a default that you should be able to use by pressing return. But, that does not work. Rather, you must type S to enter the settings. It also seems to remember those settings.I am puzzled why the command does not seem to be aware of if it is in model space, or in a viewport. So, if you set it to to a VP Freeze, the command cannot be used in model space until you change the settings back. I suppose I could make to separate macros to change between the two modes.But, I must also confess that I am not clear about all the options this command offers. So, perhaps I am just misunderstanding something about it.-Joe0
