Arrow designs in Leaders
I use a custom arrow head for all my leaders.
I find the ratio of arrow length to length of leader before the arrow appears is about 2:5.
IE the arrowhead measures 2 units and the end of line is 5 units from the start of arrow.
This is too great as it doesn't make for neatness in plans.
Changing the Arrow Size works but the arrow is too small.
A work around sometimes is to just place an arrow (block) and join a spline/ arc etc off end.
The attached image shows splined leader that I'd prefer a much shorter distance before I start curving the leader. Any shorter in this instance and it doesn't show.
I don't use dimension arrows/ leaders, they are merely to annotate my plans.
For scale, the text height is 3.125 mm.
Comments on making this work much appreciated.
(Apologies if my Cad language is up the creek)
0
Hello Richard,
I think the only problem is the way you defined your custom arrow block. Look at this example, I think it is self-explanatory:
leader_arrow.png0 -
Ahh! Bliss at last.
Many thanks Knut.
I modified my arrow and it works just as you show.
Brilliant.
aloha ahiahi0
