Prompt Box
When typing in the command line a a popup appears giving me all the options according to the letters I have typed in, can anyone tell me how to get rid of this. I have had a look in settings but can't see anything to obvious.
0
Hi Philip,
Try changing your settings for PROMPTMENU. If set = 0, then it won't display
Regards,Jason Bourhill
CAD Concepts0 -
Just tried it but it does not work, I still keep getting the popup as soon as i start typing in the command line.0
Ok, perhaps you mean Auto Complete. You can turn this of by changing AUTOCOMPLETEMODE = 0. If you look under _SETTINGS you will see the other options available. You can also play around the display delay time. See AUTOCOMPLETEDELAY.
CAD Concepts0 -
Bingo, thanks Jason you are a gem!!! By the way do you know if there is a way to lock the toolbars in position in Bricscad0
