BricsCAD v14 - Minimum Citrix Version?
Hi,
One of our clients would like to install BricsCAD v14 on a Citrix server.
I have a few questions - is Citrix properly supported by BricsCAD?
1 - Is there a minmum version of Xenapp to be used with BricsCAD?
2 - Would we need to purchase a network license for use under Citrix?
3 - Are there any other possible problems we need to be aware of when using BricsCAD under Citrix?
Thanks for any advice you can give.
0
Hi Chris,
Probably best to raise a support request for information on this, but from this Knowledge Base answer Terminal server disabled (Error code -46)
I would think you would require the network version of BricsCAD.
Regards,Jason Bourhill
CAD Concepts0
