Dimensioning
in Linux
Hi Guys, to place text below the dimension line I used the code /X in Autocad. This forced the text after this code to display below the dimension line. Has anyone used this in Bricscad?
0
The incorrect slash is noted in your post, it should be \X not /X.0
Scott is rigt. It works in BricsCAD.0 -
Sorry Guys - been away - yes got it now. Thanks for that correction.
Brian0
