Curve leader on unique layer - LISP
I have a LISP routine (no idea where from) that draws curved leaders.
I draw them on unique layer and assume it is a simple matter to change the LISP to draw on a layer of my choosing.
I've pasted the LISP below (assume it shows when I post this.
Could someone kindly suggest addition to this routine that would insert said leader on "layer of choice"
regards
(defun C:CL ( / pt ptlst)
(setq ptlst (list (setq pt(getpoint "\nStart of leader.."))))
(command "._pline" pt)
(while pt (setq pt (getpoint pt "\nNext leader point.."))
(if pt (setq ptlst (append ptlst (list pt))))
(command pt)
(command "_.erase" "L" "")
(command "_.LEADER" ptlst "" "" "_n")
(setq en1 (entlast))
(setq ed (entget en1))
(setq ed (subst (cons 72 1) (assoc 72 ed) ed ))
(entmod ed)
regards
(command pt)
(entmod ed)
0
If the layer will always be the same replace the last three lines with text (starting with '(setq ed (entget en1))') with the following. Change the 0 in the last line to the layer name you want the leader moved to, keeping the quotation marks.
;(setq ed (entget en1))
;(setq ed (subst (cons 72 1) (assoc 72 ed) ed ))
;(entmod ed)
(vle-entmod 72 en1 1)
(vle-entmod 8 en1 "0")0 -
Very many thanks Martin.
It is perfect.
Yes. Much appreciated indeed.
I looked at another LISP that placed offset lines lines onto my layer of choosing but it got beyond me so gave up.0 -
Happy to help.0
I have a different approach. Rather than LISP, I simply use a macro that I put into a button, on the command field.^c^c_dimleader;\\_format;_spline;_exit;It will create the leader formatted as a spline. It will be done in what ever the current dimension style is, and the current layer. If you don't want text, simply press Esc any time along the way.-Joe0
Thanks Joe
Sounds good - I'll have a play with that. I've never used Macros. New experience.
regards0 -
Oh! Is that available in 64 bit? Macro ie.0
A macro is simply a series of commands, as though you typed them from the command line. So, any thing you can do from your keyboard, you can put into a macro. Since you use knowledge you may already have about the commands, it is easier to do than programming in LISP.I know sometimes the word "macro" is used to refer to a Visual Basic routine. But, I am talking about the above, which does not involve programming.There are a few special codes, like the ^c [to indicate a Control-C keypress] is to cancel any current command you are in. It is repeated, because some commands take a few extra ^c to back out of the command. Then, any space or ; is the same as pressing enter.
-Joe0
