3Dclip
Greetings!
I am wondering is there in BricsCAD 2014 any similar function as 3dclip was in ACAD 2014?
I often used it ACAD 2014, but I have changed the office and now I use BricCAD 2014. It doesn't make big problems except this one function.
Thank anyone for the answer!
0
I think what you want is part of the DVIEW/CLIP command. It may be that Autodesk has modernized the command with a better user interface, but the BricsCAD version is still as it was back in the 80's.-Joe0
