Bricscad COM API and python win32com
import win32com.clientacad = win32com.client.Dispatch("BricscadApp.AcadApplication")doc = acad.ActiveDocumentmodel = doc.ModelSpacepaper = doc.PaperSpaceutil = doc.Utilityblocks = doc.Blocksprint acad, doc,model,paper, util,blockssCurName = doc.Nameprint sCurNameline = model.AddLine((0,0),(0,10))0
Could it be that :
is looking for a 3d point?
model.AddLine((0,0,0),(0,10,0))0 -
line = model.AddLine((0,0,0),(0,10,0)) # cause errorline = model.AddLine("0,0,0","0,10,0") # it worksIt's weird. In the developer's guide startpoint and endpoint is arraylike variables. In other programs such as Nanocad this code works correctlyutil.GetPoint() return arraylike variable0
The problem was with the type of the array. Bricscad requires an array type VT_ARRAY | VT_R8. Python lists do not match this type. This problem is solved with the creation of the array of the appropriate type in python by the command array('d', >).win32com replaced by comtypes library.from array import arrayimport comtypes.clientacad = comtypes.client.GetActiveObject("BricscadApp.AcadApplication")doc = acad.ActiveDocumentmodel = doc.ModelSpacepaper = doc.PaperSpaceutil = doc.Utilityblocks = doc.Blocksprint acad, doc,model,paper, util,blockssCurName = doc.Nameprint sCurNamepnt1 = array('d',(0,0,0))pnt2 = array('d',(0,10,0))line = model.AddLine(pnt1,pnt2)0
Hello all,
How do you implement your code in Bricscad? I have been working strictly in Lisp thus far, and have some Python experience and love the language. Sounds interesting.
0 -
I connect to Bricscad COM API using comtypes library. I run the script from the outside.0
I get this error when trying to access Bricscad from the Python Shell. I have imported comtypes.client and I have Bricscad running.
>>> acad=comtypes.client.GetActiveObject("BricscadApp.AcadApplication")
Traceback (most recent call last):
File "", line 1, in
File "C:\Python34\lib\site-packages\comtypes\client\__init__.py", line 180, in GetActiveObject
obj = comtypes.GetActiveObject(clsid, interface=interface)
File "C:\Python34\lib\site-packages\comtypes\__init__.py", line 1238, in GetActiveObject
oledll.oleaut32.GetActiveObject(byref(clsid), None, byref(p))
File "_ctypes/callproc.c", line 920, in GetResult
OSError: [WinError -2147221021] Operation unavailable
>>>Any ideas on what will cause this error?
Thanks,
Kevin
0 -
File " ", line 1, in
Thanks,
Kevin
Perhaps you're trying to connect to a 64 bit version of Bricscad. For this you need a 64 bit version comtypes and python0 -
Thanks Akim, I was running a 32 bit version of Bricscad. Re-installed it as 64 bit and it works. Thanks for the advise.0
