Popup task bar
Hi Guys,
Quick question.
Im new to Bricscad. I am using V15 and am delighted with it so far, however there is a pop up menu in the top right hand corner that is very distracting e.g. if I type in the "line" command all the line options pop up. How do I turn this off?
Thanks,
Eoin
0
1) Select the "Settings" menu item (see attached illustration)
2) Type "prompt menu" in search bar (see attached illustration)
3) Select "[0]" and close the Settings dialog box
The menu should not appear again.
Good luck
Prompt Menu.png0 -
Hi Dennis,Thanks for your reply.Prompt menu gone.Cheers.Eoin0
