Button icons
Hi Jim,
I have the same situation, and new to BricsCAD. I just found that if I copy an existing Bitmap (.bmp) file (another button perhaps), paste it into another folder ( I just popped it in BricsCAD Support) and then go into Customize, click on your new button, go to image (bottom of page) click on ... icon, and go to the folder where you saved your button. I will look into changing the actual button image in Paint so that I can add a few more.
I hope this helps you in the right direction.
I attached 2 images that will hopefully help.
Let me know if they don't open up
Ami
0 -
Here's a link to a fairly inexpensive icon/bitmap creator, you can also test-drive for 30-days.
IcoFx Link0 -
Thanks Bruce,
I'll give it a go
Ami
0
