Tool palette re-organizing of icons
our tool palettes are ever evolving. is there a way to move blocks/commands around within the tool palette without deleting them and re-inserting them in the new order?
0
? Have you tried dragging them around in the customize menu ?
0 -
I don't see were that's an option.0
Rightclick a toolbar choose customize pick your tool and drop it where you whant it.
Works fine for me.
0 -
The question was about toolpalettes, not toolbars.
I also see big problems in not beeing able to customize toolpalettes.
Maybe this discussion can help to get the toolpalette-functions modified.
Would also be nice to be able to organize palettes in groups - not supported yet by Bricscad.
Does anyone have a workaround for this one?0 -
You can edit the btc (xml format) files using a text editor. At the bottom there is a section for tool order. Unfortunately BricsCAD doesn't use a human friendly naming scheme, so it's a little cryptic.
Organizing tool palettes into groups isn't possible yet. If you right click and pick 'Customise Palettes...' you'll see that the potential for that is there. A workaround is to switch your TOOLPALETTEPATH to point to a different set of tool palettes. Some basic code to do this
[code]; Use User Toolpalettes
(defun C:TPUSER ()
(acet-sysvar-set '("CMDECHO" 0))
(setvar 'TOOLPALETTEPATH (strcat (getvar "ROAMABLEROOTPREFIX") "Support\\ToolPalettes"))
(command "._TOOLPALETTES")
(acet-sysvar-restore)
; Company Toolpalette global
(setq *CompanyTools* "C:\\MYCADLIB\\ToolPalettes")
; Use Company Toolpalettes
(defun C:TPCOMP ()
(setvar 'TOOLPALETTEPATH *CompanyTools*)
; Use All ToolPalettes
; Note BricsCAD V15 allows you to set multiple Toolpalette paths, but only displays the palette of the first path in the list
(defun C:TPALL ( )
(setvar 'TOOLPALETTEPATH (strcat (getvar "ROAMABLEROOTPREFIX") "Support\\ToolPalettes" ";" CompanyTools))
)[/code]
Regards, Jason Bourhill CAD Concepts0
