Select all horizontal dimensions in LISP
Hi all,
I'm looking for a way to select either all of the horizontal or vertical dimensions in a drawing through a lisp program. Ideally I want to select all the vertical dimensions then change the properties of certain ones if they meet a condition to force the text inside of the arrows. If anyone can think of a way to do this it'd be much appreciated.
0
What's the other condition? That might be easier to filter for than vertical orientation.
The following selects all horizontal dimensions (except for ones that have been rotated 180 degrees):
[code](defun c:QDHX ( / ss1 ss2)
(princ "QDHX selects all Horizontal Dimensions in the file. ")
(setq ss1 (ssget "X" '((0 . "DIMENSION"))))
(if ss1 (progn (sssetfirst nil ss1) (setq ss2 (ssget "P" '((50 . 0.0)))) ) )
(sssetfirst nil nil)
(if ss2 (sssetfirst nil ss2)
(progn (princ "\n ...none found.") (princ) )
)[/code]
I would have thought I could change the 0.0 to 1.5708 to make it select vertical dimensions (or 3.14159 to make it select 180-degree-rotated horizontal dimensions), but that didn't work. Perhaps someone else will explain why. And how to filter for two group codes at once instead of using two ssgets.0 -
I would expect that this is due to a rounding error. For example
[code](= 1.5078 (/ pi 2.0))[/code] will return nil
but if you use the equal function instead, then you can apply some 'fuzz' to your comparison
[code](equal 1.5078 (/ pi 2.0) 0.1)[/code] will return T
Regards, Jason Bourhill CAD Concepts0 -
[code](defun c:SelHor ( / fuzz)
(setq fuzz 1e-8)
(sssetfirst
nil
(ssget
"_X"
(list
'(100 . "AcDbRotatedDimension")
'(-4 . "<OR")
'(-4 . "<AND")
'(-4 . "<")
(cons 50 fuzz)
'(-4 . ">")
(cons 50 (- fuzz))
'(-4 . "AND>")
'(-4 . "<AND")
'(-4 . "<")
(cons 50 (+ pi fuzz))
'(-4 . ">")
(cons 50 (- pi fuzz))
'(-4 . "AND>")
'(-4 . "<AND")
'(-4 . "<")
(cons 50 (+ (- pi) fuzz))
'(-4 . ">")
(cons 50 (- (- pi) fuzz))
'(-4 . "AND>")
'(-4 . "OR>")
)[/code]
[code](defun c:SelVer ( / fuzz)
(setq fuzz 1e-8)
(sssetfirst
nil
(ssget
"_X"
(list
'(-4 . "<OR")
'(-4 . "<AND")
'(-4 . "<")
(cons 50 (+ (* pi 0.5) fuzz))
'(-4 . ">")
(cons 50 (- (* pi 0.5) fuzz))
'(-4 . "AND>")
'(-4 . "<AND")
'(-4 . "<")
(cons 50 (+ (* pi 1.5) fuzz))
'(-4 . ">")
(cons 50 (- (* pi 1.5) fuzz))
'(-4 . "AND>")
'(-4 . "<AND")
'(-4 . "<")
(cons 50 (+ (* pi -0.5) fuzz))
'(-4 . ">")
(cons 50 (- (* pi -0.5) fuzz))
'(-4 . "AND>")
'(-4 . "<AND")
'(-4 . "<")
(cons 50 (+ (* pi -1.5) fuzz))
'(-4 . ">")
(cons 50 (- (* pi -1.5) fuzz))
'(-4 . "AND>")
'(-4 . "OR>")
)[/code]0 -
Very clever Roy. A very good example of the power of the ssget function through the use of filters
