Universal command among different languages
Good morning,
I'm working on the development of an application based on bricscad.
Our company work with international customers and we encouter the problem of different command languages among different bricscad installations.
There is a way to send a command "universally interpreted" among the different language package.
For example the command "-mblocco" in italian version correspond to "-wblock" in english version.
Also to use a window selection mode on italian version we must specify "F" (finestra) but in english version "W" (window) it's used
Until now the solution has been to manually change the command line that we need t excecute but it is very time consuming and error prone procedure.
Thanks for any reply
Best Regards
MM
0
Preceding the English command name with an underscore (_) will launch the command in any language.0
Thanks a lot Louis.Best RegardsMM0
