Infinite Lines truncated
'Infinite' lines aren't infinite but are generally truncated so that when I need to use them for construction purposes I frequently have to 'splice' on one or more extra lengths.
Is this a bug or do I need to change a Setting somewhere in the system?
I am using Bricscad v14 64 bit.
Andrew McIntyre
Andrew McIntyre
0
Try doing a REGEN. This forces a re-calc of your XLINES for the current display
Regards,Jason Bourhill
0
