Pan displacement point
in Other
So I reconfigured my middle mouse button to bring up osnaps. In doing this I lost my pan but normall that's ok because I like to use the P command anyway. However the Bricsad default seems to be some Pan displacement feature. Is there a way to configure the Pan default to be more like AutoCADs default? Once the command is initiated I want to use the left mouse button to pan ....
0
Disregard. I found a way.0
John I have the same issue; how did you figure it out?
Thanks
raju
0 -
Change the P command to RTPan.0
If MBUTTONPAN = OFF, press and hold Shift+Ctrl and the right mouse button to pan. Since Shift+Ctrl and the left mouse button allows to zoom, holding down Shift+Ctrl, switching between the left an right mouse button allows to pan/zoom to a specific area in your drawing easily.0
That sounds interesting Louis - as long as the various 3D rotate moves can fit into that approach as well?0
@ Tom:
Are you aware of these?:
Shift+MMB
Ctrl+MMB0 -
... And:
Shift+Ctrl+MMB0 -
An overview of all keyboard shortcuts for view manipulation can be found in the BricsCAD Help under User Guide > Viewing Your Drawing > View Manipulation Using the Mouse and Keyboard.0
