Editor.Command - does not exist?
Hello,
I'm trying to write my application that works well in AutoCAD for the BricsCAD.
Till now, I don't have much problems, but I came across to the Editor.Command void.
Does anyone know, how can I send specify command to the BricsCAD? Like d.Command("FILEDIA", "0") ?
Thanks.
0
FILEDIA is a system variable, so you can directly access variables from NET, without command interface :-)
As far as I know, sending commands should not be a problem in our NET interface ?
You might send us a support request, with a sample project, so our developers can adjust + improve that,
and/or adjust and improve our NET implementation
many greetings !0 -
FILEDIA was just an example
Here is little more advanced function which invoke standard BREAK command, but user have to only once select point to break:[code]Document doc = Application.DocumentManager.MdiActiveDocument;Database db = doc.Database;Editor ed = doc.Editor;PromptEntityOptions peo = new PromptEntityOptions("\nChoose line to break: ");peo.SetRejectMessage("Tylko linia albo polilinia.");peo.AddAllowedClass(typeof(Curve), false);PromptEntityResult per = ed.GetEntity(peo);if (per.Status != PromptStatus.OK) return;ObjectId curveId = per.ObjectId;PromptPointResult ppr = ed.GetPoint("\nSelect point where to break: ");if (ppr.Status != PromptStatus.OK) return;Point3d breakPoint = ppr.Value;ed.Command("_.break", curveId, "_first", breakPoint, breakPoint);[/code]In old version (ACAD 2007) I have to do this like below:[code]Document doc = Application.DocumentManager.MdiActiveDocument;Editor ed = doc.Editor;Database db = doc.Database;PromptEntityOptions peo = new PromptEntityOptions("\nWybierz obiekt do rozbicia");PromptEntityResult per = ed.GetEntity(peo);if (per.Status != PromptStatus.OK)return;PromptPointOptions ppo = new PromptPointOptions("\nWskaż punkt rozbicia");PromptPointResult ppr = ed.GetPoint(ppo);if (ppr.Status != PromptStatus.OK)return;Point3d first = ppr.Value;ResultBuffer rb = new ResultBuffer();rb.Add(new TypedValue(5005, "BREAK"));rb.Add(new TypedValue((int)LispDataType.ObjectId, per.ObjectId));rb.Add(new TypedValue(5005, ""));rb.Add(new TypedValue(5005, "F"));rb.Add(new TypedValue(5005, string.Format("{0},{1},{2}", first.X, first.Y, first.Z)));rb.Add(new TypedValue(5005, string.Format("{0},{1},{2}", first.X, first.Y, first.Z)));Utilities.acedCmd(rb.UnmanagedObject);[/code]0 -
Anyone know why acedCmd doesn't work for me (BCAD v16):[code] [DllImport("Brx16.DLL", CallingConvention = CallingConvention.Cdecl, CharSet = CharSet.Unicode)]
public extern static int acedCmd(System.IntPtr vlist);[/code]0 -
Hi, its better to use static bool Bricscad.Global.Editor.Command(ResultBuffer args), which wraps acedCmd
Cheers
0 -
Exactly what I was looking for! I did not managed to hide my excitement
Cheers! 0
