Image Enabler
Where is image enabler in 3.2.0001?????
It came with my download. Place your cursor over the tool bars and right click to see if there is an image enabler tool bar. If so, you have the feature included in your package.
0 -
I had the image enabler in all my previous updates, (the last being 3.1.0009), but it is not there now. What's up?
0 -
Even if you closed the Image Enabler toolbar by accident, there should still be the ImageEnabler menu in the IntelliCAD menu bar.
0 -
There is no toolbar listed for image enabler and images I had previously attached to files are not visible. Do you have a fix. I am a very capable Icad user as I was one of the original beta testers for Visio, so although I appreciate all your suggestions, I had already considered them. Thank you.
0 -
I have fixed my problem as follows. I removed my current installed 3.2.0001 and reinstalled 3.1.0009 then installed 3.2.0001. I can't tell you why but it worked.
0 -
Most likely something went wrong during your first installation of ver. 3.2.
0 -
I do have the same problem. After the install of 3.2.0001 the "Smartpixel ImageEnabler Toorbar" is there, but it has 7 dummy icons. The icons have the right tooltips, and the right commands (_iemanage, _ieadjust, _ietransparency, _iequality, _ieframe, _Draworder) but they do not work . Only the last icon (_Draworder) does work. The menu item "Imageenabler" is there too, but the commands (except "Draworder") do not work either (even "_iehelp" does not).Before I take the trouble to uninstall 3.2.0001, reinstall 3.1.0009 and reinstall 3.2.001, could someone please confirm that that is really a working solution ?
0 -
I found what went wrong. If you did not reboot after closing 3.1.009, some files stayed open (I think they shoudn't but they do) and were not replaced in the install of 3.2.001. You only have to make sure that you reboot after running 3.1.009 and before installing 3.2.001. That way InmageEnabler will work OK.
0
