Convert Lisp Functions from AutoCAD 2004 to be used in BricsCAD V13
We have a drafter creating drawings using AutoCAD 2004 because of the Lisp Functions that were programmed for him. That programmer is no longer with the company and we would like to convert them so they can be used in BricsCAD V13.
Seeing if there is a service or a person that would do that type of work or is there a program that would analyze the Lisp files and do the conversion from AutoCAD to BricsCAD.
Thanks
Matt
0
Hi Matt,
I provide a service to assist clients making the transition from AutoCAD to BricsCAD. I have an example here
http://www.cadconcepts.co.nz/bricscad/bricscad-setup/
Generally LISP is relatively straight forward to bring over. Usually the tripping point is around command calls.
Regards,Jason Bourhill
0 -
Thank You, I will look at the information on the link. I will get in touch with you later to see what can be done.Matt0
