linetypes in hatches
We have recently purchased Briscad; our existing system runs AutoCAD 2007 LT.
In AutoCAD, I can change the linetype within a hatch and it will display and print with the new linetype.  (For example, giving a Phantom or Dashed linetype to a simple hatch pattern ANSI31).  However, in Bricscad, the linetype does not show the dashed lines, it just displays solid.  I can have adjacent polylines with the dashed properties, and use match properties to apply the linetype to the hatches.  The polylines will display with the dashed properties, but the hatches always show a solid linetype, even though they show "phantom" or "dashed" as the linetype in the properties.
Any ideas of how I can get the different linetypes to display in hatches?
Thanks!
  • In more recent versions, AutoCAD introduced the HPLINETYPE setting, which controls the display of non-continuous line types in hatch patterns. This setting is Off by default.
Welcome!
It looks like you're new here. Sign in or register to get started.
