How to use ''Divide'' function
Hi,
I.m new on Briscad. How I should use the DIVIDE command?
Thans
0
See the BricsCAD Help under User Guide / Modifying Entities / Measuring and Dividing Entities and Command Reference D/Divide.0
Select the line to divide, then specify how many sections to divide it into. It doesn't actually do anything to the line. It just puts points at each division point, which you can snap to using the Node osnap. If you want to actually divide the line itself, you have to use the Break command, snapping twice on each of those points.0
Thank you! I use the Briscad help. My Point display mode weren't set properly.Now I can use the command correctly.0
