Lisp editor for bricscad
-What makes BricsCad-lisp developers regarding writing a code. I miss a little a corresponding "VLIDE" so we at least get a little syntax-check out etc.
0
I use Notepad++.0
There are several threads about this. We use UltraEdit. The Wordfiles for Lisp enable command highlighting and autocomplete. It works pretty well.0
