Text Height
For some reason I cannot control TEXT height. The option to enter text height after entering the TEXT command is not available presently but has always been
in the past. Some variable must be off when it should be on?? Please help with the correct info.
Thanks.
0
Does the style you are using have the height set to 0?0
Only if the Height field of the text style is 0 (zero), you are prompted to set the text height. Otherwise the text height is taken from the defined height. But you can still modify the height afterwards.0
Thanks for your help. That was the problem.0
