Customi CUI file commands in German
HI,
I have loaded our Teams Custom CUI file, through the Partial Load command and it loads up fine but
when clicking on commands the prompts and dialog boxes appear in German?
The same CUI file is used by several others with no problems....
any help?
Thankyou,
0
The only logical explanation I can come up with is that you have installed a German version of BricsCAD.0
Perhaps this custom setup includes, or is Express Tools for BricsCAD? This includes German and English versions of the CUI. To switch to the english version of Express Tools you can type MENU_ENG at the command prompt.
Regards,Jason Bourhill
0 -
Yep it includes the express tools.
When the command Menu_ENG was typed is just came up as "nil"
I unloaded the custom menu and the express menu, brought it in again and now its working fine.
Not sure what changed.
Thanks
0 -
Typing MEN?U_ENG at the command prompt returns 'Unable to recognize command "MENU_ENG". Please try again.Is there another prompt command to change the MENU language?
Regards,Jason Bourhill0
