List of System Variables
Is there a list of "System variables" for V16 anywhere?
Thanks
CAB
Thanks
CAB
0
You can use the Export button in the _Settings dialog to create a .csv file.0
On the command line run the following:setvarVariable name or ? : ?Variable(s) to list <*>:The system will open the prompt history and output a list of all the variables and their value. Keep pressing enter to cycle through the list.0
