V17 Layer Panel - search box
The Bricscad Layer panel's Filter Function is not usable. There is no way for using Wildcards in the searching box. If i want to filter all Layer which starts e.g. with the Letters: ARC the live search is showing everything which have these 3 Letters in the Layer name.
Maybe im wrong, because im to incompetent for handling this filterlist.
Using the Layer part of the Drawing Explorer everythink is fine - there the Wildcards are working as known before.
0
You can define layer filters in the Drawing Explorer / Layers, which can then be selected in the Layers panel.0
