Layouts
Hello.
A bigger amount of layouts is very difficult to handle.
It´s hard to find a certain layout as you have to click through all your layouts.
A mess, if you changed something effecting e.g. layout 3, 10, 24 and 50 and you must update the header.
Does anyone have a solution?
A list like in the drawingexplorer would be cool to select layouts.
The possibility to tell a new layout where it should appear (like in ACAD "before..., after...") would also be cool.
Are there any tools?
Thank you,
Sascha
Thank you,
Sascha
0
0
Pretty cool.
But is there a possibility to keep the window open while drawing?
And how can I extend the window to be able to see the whole list of layouts?
Thank you.
Sascha0 -
Pretty cool.
Thank you.
Sascha
It's not possible using this code. There's shurley no other way as developping an Tool you like. But you need at least an Pro Version, i guess.
Regards
Martin0
