Superhatch
How can I add a folder with all my superhatch's to Bricscad? I can do this in autocad (options) in the file system adding the path to the folder, but I don't know how to do it in Bricscad. I am new using this product. Thanks for your help
0
Add the folder(s) where you have saved your hatch patterns to the SRCHPATH system variable:Choose Settings in the Settings menu, then go to Program Options > Files > Support File Search Path and click the Browse button at the right hand side of the settings field. You can add all your folders containing *.pat files here. Hatch pattern definition files (*.pat) must have the same name as the hatch pattern name in the definition file. To select a custom hatch pattern file in the Hatch dialog, choose 'Custom' in the 'Type' list, then click the Name or Swatch field.0
Thanks!!!0
