Array dialog box - how to get it back
Just in case anyone else was wondering and maybe even missing the array dialog box... use the command ARRAYCLASSIC.
This has been driving me crazy for the last week after we upgraded to v17, even went back to v16 and the dialog box is missing from it too now. I dont quite understand that, but the command line or other command box version of array is way to clunky and wastes far too much time to deal with.
0
Hi
Set your array command to ARRAYCLASSIC
h.0 -
AHA
First read, then write :-)
have a nice day
H.0 -
Thanks. It drove me nuts too, till I saw this post. Why do you suppose they did that?0
It is not that the dialog box disappeared. Now the arrays are associative. You will have immediately an array and can modify all settings in the properties bar. You want to have 5 rows instead of 3 rows – now you can do this in a second.
0
