wrong first result of (grread 5)
Hi,
in BricsCad V16 or 17 I get wrong result when calling grread for the first time ...
1. call ... (grread 5) ... 1. result eg ... (5 ((64754.2730523668 23733.1387015457 0.0)))
>1. calls ... (grread 5) ... result eg ... (5 (64754.2730523668 23733.1387015457 0.0))
Consider: just in the 1.result the last value is a point in a list!
Can you confirm this lisp interpreter bug?
Thanks in advance ...
Peter
Peter
0
No, i can't confirm this.
i always get the call like this format: (5 (64754.2730523668 23733.1387015457 0.0))
I tried V15,V16 and V17 german0 -
@ martin ...
thank you very much for your response !
this will help me ... if I've found the reason I will tell you!
thanks again ...
peter0
