Datamatrix 2D-Code Generator within BricsCAD ?
Is there an application for BricsCAD available that can generate Datamatrix 2D-Codes?
0
With 2d Datamatrix you mean something like a QR-Code?
Maybe silly question, but why wouldnt you just use a online qr generator and import it as .eps file?
I havent stumbled across anything like it as an addon.0 -
I started one a while back, ECC 200 and QRCode, I never finished it though : |
I could probably make something “no frills”, Although, if your just needing one or two, it might be easier to use an online generator and attach the image.
0
