Facetres command
Not supported. Which command replace the facet resolution command in order to export the model to a rendering software?
0
Maybe i should point out that polyface meshes and acis solids are different. You ask several questions about meshes as if they are solids. They're not. Solids can be sliced, united etc. Full Acis support is currently being completed. There are Intellicad issues that already support solid viewing.Up till now Intellicad has largely been a 2d drafting software. 3d had to come from extra applications on top of it. So this is changing.regards, sander
0
